Portal for ArcGIS pop-up option missing when adding map service
3594
04-24-2015 11:26 AM
LucasMurray2
I have Portal for ArcGIS and ArcGIS for Server v.10.3 set up so I can publish services to Server and can share those services to Portal.  In other words, I'm publishing my services using Server manager and not Portal.  I have Server Manager successfully sharing services with Portal.  Once a map service is published, I set the Sharing for the service to "Everyone."  In Portal, I can add the service to a map successfully.  However, there are no options within the map to view the attributes of the map service (i.e. no options regarding the attribute table or the pop-up window).  I've looked over the internet and some sites have suggested the map service needs to have feature access enabled.  However, the map service is coming from a file geodatabase.  I don't have an enterprise database system available at this time.
Is there a way to at least get a pop-up window option added to the map in Portal?
Thank you,
LMM
JakeSkinner
Esri Esteemed Contributor
Hi Lucas,
Are you drilling down far enough into the service to enable pop-ups?
JakeSkinner
Hi Lucas,
LucasMurray2
Thanks for the quick reply.  That worked.  I knew it was something simple but I couldn't figure it out.
Thank you,
