Portal for ArcGIS Editor
1030
06-30-2017 01:20 PM
DOMLECGIS
Hi all,
I'm trying to edit with a map I created which has a feature service with data that is registered on a local enterprise geodatabase on the GIS Server machine. When I try to edit and add points or lines for certain layers the pop up window does not appear, however it does work for a few other layers.
Has anyone encountered this problem before? I'm using ArcGIS 10.5 also I tried it with Chrome, Firefox and Edge browsers with same result.
Gideon
RandallWilliams
Do your browser's debug tools provide a hint as to what's happening? Or the portal logs?
DOMLECGIS
Hey Randall.
I figured it out. My feature classes has M and Z values enabled so I simply enabled a default Z and alowed geometry updates without m-value.
worked like a charm!!!
Thanks !
