portal for arcgis 10.3
4487
5
12-27-2014 08:58 AM
ManeshSharma
Hi all
Can anybody help me , i have installed the portal for Arcgis 10.3, and me able to login in that account. After that i installed Webadaptor for IIS , and when configuring it , it is aksing for machine.domain.com:7443
i provided mine machine name.esri.com:7443.
and mine portal administrator login id and password. but it is giving me the error
As i dont have the domain name . How can i configure it for mine use.
please do send me the Steps for the same.
RandallWilliams
I think we'll need more detail in order to proceed.
For instance, are you I see you're using machinename.esri.com:7443.
Did you format that URL like this, using the https prefix: https://machinename.esri.com:7443.
What specific error are you seeing?
ManeshSharma
Hi Randall Williams
How r u , Happy new year in advance to You. Yes i am using the same prefix. when i login using the same it gives me the url portal domain authentication error.
RandallWilliams
Thanks, I appreciate it. I hope yours is also good.
Can you post a screen capture of the error? I'm assuming you're using the portal initial admin account, and not a domain account to configure the web adaptor. Is this the case? Is the web adaptor installed on the same machine as Portal? It really shouldn't matter, but it would be good to know.
ManeshSharma
Hi Randall
Thanks for the reply,, yes me using the Admin account. yes the Web Adaptor is installed on the same machine.
larryzhang
It looks that your issue is mostly related to Web Adaptor (IIS) and web server IIS installation /configuration.
pls check and compare the Doc at Installing ArcGIS Web Adaptor—Installation Guides | ArcGIS for Server
and see if you can get it fixed...
