Portal - Find group a webmap is assigned to
460
09-29-2019 04:52 PM
JosephJose
I would like to use this without any sort of scripting in the Portal interface
Is there an option in the webmap to know which group a webmap is assigned to? Preferable in the "Webmap" settings or other
I could come the reverse way from the groups to the "Groups" -> "My Organization's Groups" -> selecting the appropriate group if I know it.
StevenRamirez
Hi Joesph,
 Thanks for posting your question to GeoNet for other members of the community to see. The question "Is there an option in the webmap to know which group a webmap is assigned to? Preferable in the "Webmap" settings or other". Should be possible by viewing the WebMap item details page. Then under the sharing properties will display which groups this item is shared with. Hope this helps.
JosephJose
Thanks Steven
I can check the "Share" button in the item details. My problem is that the web map belongs to someone else and the "Share" button isn't enabled
