Pop-up on Imagery Layer – How to hide selection in Map Viewer?
930
7
05-05-2025 07:30 AM
MatthiasKl
I have published an imagery layer and enabled pop-ups. In the new MapViewer, I get the pop-up but also a cyan-coloured selection frame. In the old mapviewer there is no selection frame visible. I have attached two screenshots that illustrate the problem.
How do I get rid of this selection frame? We use ArcGIS Enterprise Portal 11.3.
MatthiasKl
Just in case someone is facing the same problem: You can customize the highlight fill and outline in the map widget. So to hide the selection frame, you can simply assign colours with 0% alpha for both.
Sadly, this option is only available in the map widget of an Experience and not in the MapViewer.
Laura
by MVP Regular Contributor
MatthiasKl
The linked thread is about 'focus rectangles' for the MapView. My question is about the selection that pops up when you click on the imagery layer to get the pop-up with the pixel value. You can see it in this example: https://developers.arcgis.com/javascript/latest/sample-code/layers-imagery-popup/
BlakeTerhune
MVP Alum
Is this as simple as just disabling the pop-up on that layer?
Configure pop-ups (Map Viewer)—ArcGIS Online Help | Documentation
MatthiasKl
If I deactivate the pop-up functionality, I don't get a selection frame. That's true. But that's not what I want. I need the pop-up and it seems to work as desired in MapViewer Classic.
BillFox
MVP Notable Contributor
does this help?
Is it possible to change the selection color in ArcGIS Online Map Viewer?
https://support.esri.com/en-us/knowledge-base/faq-is-it-possible-to-change-the-selection-color-in-ar...
MatthiasKl
No, according to the linked article it's not possible to change the selection color in the MapViewer. It's only possible creating a web app using ArcGIS Web AppBuilder which has been retired some time ago (and will no longer be available in the next release).
MatthiasKl
