Does anyone know what this means please?
Service to Provider Hive is not enabled for this tenant '0123456789ABCDEF'.
Trying to perform analysis in Portal for ArcGIS 10.4 map view, keep getting this error message.
Lara
Hope this is better.
I have been contemplating whether or not to try Matthew's suggestion, that's why I haven't replied to him yet. It took me a while to get my server federated and everything except the Analysis is working and I'm too afraid to meddle with it.
Lara
I ran into the same problem--I was able to fix it on my end, but I'm not exactly sure why it fixed it. I'll explain what I did--you might look into it as well.
When I originally federated my Portal, I didn't have a web adaptor configured with ArcGIS Server. So when federating, I used port 6443 for both the Services URL and the Administration URL. Setup this way, I watched Fiddler while running an analysis task in Portal. Looking at the input parameters for the SubmitJob task in Fiddler, all of the services are being called and created over ports 6443 and 6080. I don't know that this is inherently wrong or not, it just struck me as abnormal.
I installed a web adaptor for ArcGIS Server (separate from the Portal web adaptor, which is required), and un-federated and re-federated, using the web adaptor URL for the Services URL. After doing this, Analysis worked successfully.
Thanks Matthew for your reply.
I am still contemplating whether or not to try your suggestion. It took me a while to get my server federated and everything except the Analysis is working and I'm too afraid to meddle with it. I'll let you know if I decide to do what you did and the outcome for me. Thanks again. Your help is truly appreciated.
Lara
Yes, that makes sense. The environment I was using was a brand new test environment, where it was OK to break things. There have been cases where there are problems re-federating after un-federating. I'd suggest doing a system-wide backup before trying this.
Hello Matthew,
I finally summoned up the courage to try out your suggestion. It worked!!! and just like you, I'm not absolutely sure why the server web adaptor made the difference. The most important thing right now is that Spatial Analysis on Portal works like a charm! Thank you so much for your suggestion. I can now move on to other issues. My work is never done.![]()
Lara
Hi Mattew,
I'm facing the same problem to run spatial analysis in Portal or ArcGIS 10.4. I went trough the documentation is it was fine. I can publish hosted service, is federated using webadaptor context. Just Spatial Analysis in Portal doesn't work. The message is {"messageCode": "AO_100105", "message": "CalculateDensity failed."}
My federation property:
"portalUrl": "https://win104.img.local/portal",
"privatePortalUrl": "https://WIN104.IMG.LOCAL:7443/arcgis",
"portalSecretKey": "621e614a64ca47f0aa50386149e0e8cb",
"portalMode": "ARCGIS_PORTAL_FEDERATION",
"serverId": "rQJ7VcQSne6EhbQq",
"serverUrl": "https://win104.img.local/arcgis"
Shoud I try to unfederate and federate again?
Thank you!
Best Regards.
Were you able to find a solution to this issue? I'm facing the same problem where the CalculateDensity analysis will return "CalculateDensity Failed" with almost no other information. It also has the message code AO_100105.
I turned the logs on to debug and did not see anything of use. Basically just the traffic of creating the service, updating the service, and then deleting the service. Couldn't find any sort of errors or explanation why the analysis was failing
The strange thing is that I can get most of the other analysis tools to work it is just CalculateDensity that has been giving us trouble
This error is because of insufficient license level of ArcGIS Server. This tool using Spatial Analyst capabilities and so the ArcGIS Server Advanced license needed
It will be great if esri will inform about such errors by more informative messages)
Our customer encountered with the same problem. The answer of Esri support was following.
As you have mentioned that the customer has a Standard license of ArcGIS for Server, this appears to be a known behavior. It has been reported as a defect with the following information:
BUG-000096375: Performing analysis fails in Portal for ArcGIS while using the Interpolate Points tool in the Analyze Patterns toolset when ArcGIS for Server is authorized with a Standard (Enterprise) license.
BUG-000100371: It should be documented that the ArcGIS Spatial Analyst for Server extension is required to perform analysis tasks in Portal for ArcGIS.
Have a nice day!
