Offline default Elevation service (11.2)
250
07-28-2025 05:13 AM
PaulJohns
I am trying to configure an elevation service for an offline portal installation following the available documentation, but I have not achieved any positive results. I downloaded SRTM data and published it as a tile layer to the host directory. Then, I tried to configure this published service as a local elevation service, but I received an error stating that my service is not an elevation tile. I have also tried publishing it as an image service and as a map service, but the result is still negative. I would be very grateful for any support. Thank you.
