oAuth connection from Make (Integromat) to ArcGIS Enterprise Portal keeps requiring reauthorization
2560
7
08-17-2022 10:39 AM
Andrew-Bowne
I have created an automation using Make (Integromat) that connects to my ArcGIS Enterprise sever using oAuth.  The problem that I am finding is that every few weeks I have to reauthorize the connection.  This proves to be problematic as the intent is for this automation to be... automatic!
I built my automation following the following Field Maps blog:
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/use-webhooks-to-automate-workflo...
Is there a reason I would have to keep reauthorizing?  Or, is there a way I should have it set up so that this doesn't keep happening?
JayJohnsonWashoeCounty
I am having this same exact issue.
I've tried increasing the SLEEP time and that doesn't help.
Jay
Washoe County GIS
Andrew-Bowne
I believe that the token times out if there is no activity after two weeks.  What I have done is write a Python script that sends a request to the webhook every day so that it doesn't time out.  So far it seems to be working.
Good to know that you've found a work-around.  My webhook is based on a new feature being added to a feature layer.  Can you share any detail on how your Python script is sending a request to the webhook?  I haven't seen any examples of that yet.
Jay
Washoe County GIS
Andrew-Bowne
What I did was set up a scenario with a custom webook that connect to Portal, extracts the server token, then makes a basic HTTP Request to a feature layer through it's REST endpoint.  That "seems" to be adequate to keep the connection alive:
Then I have a Python script that makes an HTTP request to the custom webhook.  The script is set to run every day using Windows Task Scheduler..
Thanks Andrew.  I'll give this a shot.
Jay
Washoe County GIS
rachelm
Can you just use a basic HTTP request within Make to do the same thing?  That way you dont need to use different platforms.
