Not all layers are publishing (No error Messages)
229
10-14-2021 01:37 PM
ByronUsswald
Hi there,
I seem to be having an issue with publishing. When trying to publish a feature service, I see every single layer published in my map service, but in the feature service, layers are missing. Has anyone experienced this before?
JayantaPoddar
Are you publishing from ArcMap to your GIS Server?
Try publishing only the Map Service (Don't enable "Feature Access" while publishing). Once the map is published successfully, Edit the Service > Capabilities > Enable "Feature Access" > Save and Restart.
Refresh the REST directory URL, if required. Does the issue persist?
Think Location
ByronUsswald
Hi Jayanta. No luck... I enable feature access from server manager and then get an error once the service is published saying service was published with errors.
Layers are still not present in the feature service. Any other ideas that could help?
