NAD_1983_CSRS_UTM_Zone_13N
3281
11-06-2012 05:39 AM
NolaStein
Hello,
I am working in NAD_1983_UTM_Zone_13N and have acquired data in NAD_1983_CSRS_UTM_Zone_13N. I was using the Project tool and the NAD_1983_CSRS_To_WGS_1984_2_ + WGS_1984_(ITRF00)_To_NAD_1983 transformation on my shapefile. Does this seem correct? I was just looking for clarification.
Thank you in advance.
Sincerely,
Sarina
MelitaKennedy
Esri Notable Contributor
Hello Sarina,
The transformation is putting together two transformations that try to account for the differences between NAD 1983 / NAD 1983 CSRS and WGS 1984. If you can acquire the NTv2 grid file, SK83-98.gsb, for Saskatchewan (I assume that's where the data is located), that will give you a direct transformation and should be more accurate. Here's some information:
http://www.esri.ca/en_support/1462_3321.asp
Regards,
Melita
MelitaKennedy
Hello Sarina,
Regards,
Melita
NolaStein
Thank you Melita.
I just tried to contact Larry Cook at ISC and the email address on the link you provided is no longer valid. I will try to acquire the NAD_1983_To_NAD_1983_CSRS98_2  NAD_1983_To_WGS_1984_7 transformation from another contact at ISC.
NolaStein
Melita,
How do I copy this transformation into my pedata folder?
-Sarina
MelitaKennedy
Hi Sarina,
You just need to copy the gsb file to pedata\ntv2\canada in your ArcGIS installation folder. You will probably need to create the canada folder.
http://support.esri.com/en/knowledgebase/techarticles/detail/22608
Melita
