Mosaic dataset : wrong value range
3754
09-05-2013 10:01 AM
YvanStg
Hello,
I'm trying to create a mosaic dataset to display rasters using TimeSlider.
When I add a raster to the mosaic dataset, the value "range" (High/Low listed on the side of the Color range in the table of contents) is different from the raster's (see screenshot)[ATTACH=CONFIG]27238[/ATTACH].
Raster's value range : High: 19653.3/Low: 2.60475
Mosaic dataset's value range: High : 3.40282e+038/Low : -3.40282e+038
My raster in is 32-bit float. So is the mosaic dataset.
Any idea about why this happens and how to fix it ?
thanks a lot,
Yvan
deleted-user-yIALGElyA_K9
I am having the same issue. Did you ever figure this one out?
thanks,
Jacob
brock82
I'm also having this problem. Has anyone out there encountered this before?
