Measurement Results not appearing as User using Measuring Tool
1624
01-05-2021 01:27 PM
cardiokan
Hi guys,
I am using ArcGIS portal 10.8.1
I am using the measurement tool in WAB and i get no results in the measurement results.
The strange thing is if i login as an admin, this works fine and I can see the results.
Any idea why this might be the case as a viewer user I can't see the measurement results?
by Anonymous User
Not applicable
@cardiokan, have you tried restarting the ARcGIS Portal Service?
Also try restarting the Hosting Server just to refresh everything that is being used by the Measurement widget.
PatrickMcGarry1
I am getting a similar problem with the Measurement Tool on Portal WAB 10.8.1. Did the server & service reboot solve this issue?
SophieSanders
Just wondering if anyone found a resolution to this issue?
