Hello,
We have an ongoing issue that Map Image Layers in our organization's Portal are rearranged after an overwrite.
For Example: I have a Stormwater MIL with 5 layers in Portal that is in several web maps/apps. When I am required to overwrite the layers become jumbled. Pits (point) data appears under pipes and pipes (lines) under pits etc.
I have no option but to remove and reload the MIL into the webmap and reset all configuration on the layers (pop-ups, labelling etc).
I would like to know if anyone else has experienced this problem? Am I better off including a Feature layer for stability or will this make no difference?
Regards
Rebekah
