Load Balancer Health Checks failing
1868
6
10-01-2018 08:23 PM
GillPaterson
We have set up a highly available environment with Portal, Server and Geoevent and are using a Radware load balancer. The load balancer requires to do a health check of the individual machines within the group using the following URL.
https://Portal macine name/gisportal/portaladmin/healthCheck
https://AGS machine name:6443/arcgis/rest/info/healthCheck
https://GE machine name:6443/arcgis/rest/info/healthCheck
When the individual machines are checked manually through a browser, the status is returned as ok. When checked through the Radware lb, it fails. Has anyone used Radware before and had the same issues and resolved it please?
We have checked IP addresses and that the correct ports (7443 and 6443) are registered in the LB.
Thanks in advance.
JonathanQuinn
Esri Notable Contributor
What is the response code of the health check? Are you going from LB -> Web adaptors -> Portals?
GillPaterson
We do have web adaptors in the mix and for Portal we seem to be using the WA address as it uses gisportal/portaladmin/healthCheck, but for the two AGS sites we are going straight through to the servers. If we were checking through the WA, the URLs would be:
- gissite/rest/info/healthCheck
- gisgesite/rest/info/healthCheck
I will try and find the exact error message from the LB team, they have only passed on that it fails.
GillPaterson
It turned out that the person who had entered the LB rules hadn't put a capital 'C' in healthCheck, and hadn't checked the logs (they claimed that there were no logs, they were proved wrong). All working fine now.
SaurabhUpadhyaya
We are deploying ArcGIS Servers(On Premises- Due to Date Security Restriction). Previously we are using Load Balancer to connect both ArcGIS Server and not using any Enterprise Portal.
Now we have Enterprise Portal and ArcGIS Servers are federated with Portal(Only 1 Portal Server). we are planning to use load balancer and not able to found any esri document/help to add the load balancer.
2 ArcGIS Servers
1 Portal
1 Load Balancer
1 Postgres DB Request to all of you please suggest
SaurabhUpadhyaya
@JonathanQuinn can you please check
SaurabhUpadhyaya
proposed_arch.pngplease check this diagram
