Line Symbology with Arrow
3394
08-15-2011 02:12 PM
JustinSmith
I am attempting to build a serious of polylines that would have an arrow on the end of each.  I want to make each polyline a certain thickness depending on an attribute.  However, when the larger I make the line and the arrow the arrow does not stay at the end of the line.  Anothe issue is that not every line has a from/to in the same direction so depending on how I change where the arrow is on X and Y it will work on some and not on others.
It seems very strange that ESRI would skip over the arrow feature as it would be a common symbol used in mapping.  Does anyone know of a way I can use an arrow and line as symbology where no matter the size, and angle everything is proportional and looks like an arrow?
That would be great.
Justin
