Left Justify Label Using Arcade in ArcGIS Portal/ArcGIS Collector
1398
12-19-2022 01:27 PM
DeanChauvin
Hello.  I'm publishing an MXD from ArcGIS Desktop (v 10.8.1) to Portal for ArcGIS  (v 10.8.1) so the map can be viewed on an iPad using ArcGIS Collector.
I have a multi-line label I'm applying to one of the layers.  In the Portal Map Viewer in a web browser, the label is still single line when using TextFormatting.NewLine (no big deal), but it is correctly stacked when viewed in ArcGIS Collector.  Unfortunately, though, the stacked label in Collector is center justified and it looks silly.
I tried adding some HTML tags to the Arcade expression, but no dice.  This is the expression that creates this label:
$feature["MAINT_6_YR"] + TextFormatting.NewLine + $feature["NOTES_6_YR"]
Am I overlooking some text formatting options in Arcade?  Is there some trick to get HTML tags to get this left justified?
GordonSumerling
Hello @DeanChauvin. The labelling capability in ArcGIS Collector is limited and ArcGIS Collector is no longer supported. Looks like it is time to swap to ArcGIS Pro and ArcGIS FieldMaps. You can use arcade scripting to acheive the labelling structure your after and it is supported in, ArcGIS Pro, the JavaScript 4.0 Map Viewer and Field Maps.
