Labeling Help:  How do I select only the last three digits to be labeled
4658
08-29-2011 02:47 PM
DianeRodrigues
I have parcels labeled in the following format "aaa-bbb-ccc" but on the display I want only "ccc" to be shown.  How in the world do I do that?
DonovanCameron
You can do this dynamically with something called a  label expression.
An example label expression would look something like:
Right ( [Field], 3 )
The picture shows how to get to the Label expression window from the 'Label' tab; although the expression shown in the graphic will need to be updated to something similar as the code example above.
