Label Expression to not label if...
1685
09-29-2010 08:38 AM
DonovanCameron
I am wondering how to get my label expression to not label a field if certain other fields are found.
Below is my expression.
Function FindLabel ( [LTSA_LOT] , [LTSA_BLOCK] , [LTSA_PA4] , [LTSA_PLAN] , [LAND_AC6] )
 if ( Len ([LTSA_LOT]) <> 0) then
  str1 = [LTSA_LOT] & " - "
 end if
 if ( Len ( [LTSA_BLOCK] )  <> 0) then
  str2 =  [LTSA_BLOCK] & " - "
 end if
 if ( Len ( [LTSA_PA4] )  <> 0) then
  str3 =  [LTSA_PA4] & " - "
 end if
 if ( Len( [LTSA_PLAN] ) <> 0) then
  str4 =  [LTSA_PLAN]
end if
 if ( Len( [LAND_AC6] ) <> 0) then
  str5 =  [LAND_AC6]
end if
 FindLabel = str1 & str2 & str3 & str4 & VBNewLine & str5
End Function
I would like the label to not label Str5, if labels are found for str1-4.
Appreciate your time to help me with this.
KenBuja
MVP Esteemed Contributor
Here are two ways of looking at it. If you want to add the attribute for LAND_AC6 only when none of the other fields have any attributes, then use this.
    str = [LTSA_LOT] & " - "
  end if
      str = str + [LTSA_BLOCK] & " - "
  end if
         str = str +  [LTSA_PA4] & " - "
    end if
    str = str +   [LTSA_PLAN]
  end if
    str1 =  [LAND_AC6]
   end if
  if (Len(str) > 0) then
    FindLabel = str
  else
    FindLabel = str1
  end if
 End Function
If you want to add the attribute for LAND_AC6 if one or more of the other fields don't have any attributes, then this should work
  dim found
  found = True
  else
      found = False
   end if
  else
      found = False
  end if
  else
       found = False
    end if
  else
       found = False
  end if
    str1 =  [LAND_AC6]
   end if
  if found then
    FindLabel = str
  else
    FindLabel = str & vbNewLine & str1
  end if
End Function
DonovanCameron
Perfect, thanks Ken,
never thought of the Found=False parameter or setting desired labels to one str!
BrittBurns1
I'm having some trouble. I have two fields that I want to label because on some rows, the data is different. What would the expression be if I wanted to label both fields but tell it not to label second field if values are the same? Thanks in advance!
DonovanCameron
...What would the expression be if I wanted to label both fields but tell it not to label second field if values are the same?...
Check out this similar thread from the Cartotalk forum to compare two fields for matching records with some options for a label expression.
Function FindLabel ( [F1], [F2]  )
    intComp = StrComp( [F1], [F2], vbTextCompare )
      if intComp = -1 Then
          FindLabel = [F1]
        Else
          FindLabel = [F1] & " - " & [F2]
    End if
End Function
Results:
[ATTACH]7782[/ATTACH]
In the expression the logic is: if they match, label only [F1], but if they do not match, label [F1] and [F2]
DonovanCameron
I went over a way how to compare two fields for matching values in a label expression over on the Cartotalk.
There is another method mentioned in there, but using the StrComp function you would need to make a small change to the expression:
        Else
          FindLabel = [F1]
    End if
End Function
Results:
[ATTACH]7784[/ATTACH]
