Label Expression not publishing in Portal from ArcMap10.6
354
06-10-2021 03:11 PM
ElisseDeleissegues1
New Contributor II
I am using ArcMap 10.6.1 to publish Map services to Enterprise 10.61
These services have been published for quite some time in the same way, utilizing the same .mxd and the same rest service.
The published service in question here originates from a parcel fabric sde. The parcel fabric production that provides this data is overwritten nightly from the edit default (in case that matters)
All of this, including the original services and .mxd projects, were set up before my arrival and I have not altered anything.
The issue is that suddenly there are some labels that are not showing in the map service while others are....
This label expression publishes perfectly, just like it always has:
[ENCUMNAME] + "\n" + [STATEDAREA]
This label expression, however, does not:
[PARCELID] & VbCrLF & "area: " + [StatedArea]
I have attempted:
[PARCELID] + VbCrLF + "area: " + [StatedArea]
(This returns the desired label)
[PARCELID] + "\n" + "area: " + [StatedArea]
[PARCELID] + "r\\n" + "area: " + [StatedArea]
These return an expression thus
However, no matter what I have tried the ParcelID label will not appear AT ALL in the ArcGIS Enterprise Map Service.
I have tried changing the Scale Range, Standard vs. Maplex and various other settings that may affect the outcome.
In all instances, hhis is the resulting Map Service label return
Can someone please explain to me what I am doing wrong?
