Is there an ability in ArcGIS Portal 11.4 Experience Builder to dynamically list & filter values when typing into a Query widget
330
03-20-2025 02:39 PM
apseifert
Is there an ability in ArcGIS Portal 11.4 Experience Builder to dynamically list values and filter when typing into a Query widget.  This existed in web app builder enterprise 10.8.1.  This is where a user typing in values to a Query widget search would see values listed, the list would shorten as more is typed, and a user could select from that dynamic list and see results.  User could also fully type in a query search field and see those results.  Attached is an image showing that 102 was typed in and the list values  are shortened to just those starting with "102".  Currently from what I can figure out, the user would have to type a value 100% correct to locate that matching record.
