Is there a way to add fonts to Portal?
463
03-14-2025 12:49 PM
phess_luckstone
Is there a way to add fonts to our ArcGIS Enterprise Portal?  We have some fonts that we pay for and for branding purposes we would love to be able to label features in a web map with our font.  While I love making maps in Pro for our company to use in PowerPoint with the correct font, I would really love for the ability to have a more digital solution for our people.
If anyone could help that would be great.
RyanUthoff
MVP Regular Contributor
PaulJohns
I did this by simply applying custom fonts (clicking on the font file and installing it as a system font) on the local machine where ArcGIS is installed. Then, I installed the same fonts on the virtual machine where Portal is installed. The fonts were saved as *.ttf files.
phess_luckstone
I have the font's installed on the machine.  Also Portal is installed on the same machine as our base deployment.  I have them as ttf files, are there other folders to install these into?
(From Experience Builder)
(From Map Viewer Classic)
(From Map Viewer - Searched for my font and isn't there)
PaulJohns
Hi. By default, you need to simply double-click on the *.ttf file. All installation processes should take place in the Windows system directories. So, in your scenario, you’re using the same machine for both the "publisher" and the "portal deployment." In this case, everything should work properly after double-clicking each *.ttf file (make sure the installation completes successfully—the "Install" button should become disabled).
