Is there a size limitation to add content to Portal for ArcGIS ?
3151
03-03-2015 07:28 AM
Sri_VarunMuthyala
I know that portal users with create content privilege can create content in portal by uploading files from their local desktop.
Is there a size limitation that ESRI restricts ?? Also what is the physical location of these files that are being copied to the server?
JakeSkinner
Esri Esteemed Contributor
Hi Sri,
There shouldn't be a size limitation.  When an item is uploaded, such as a zipped shapefile, it will be stored in a folder at the following location:
C:\arcgisportal\content\items
