Is it possible to modify service configurations to display domain coded values by default wherever map service is used?
1034
11-15-2022 05:02 PM
EmmaHatcher
My team is looking for a way to configure a map service (published from ArcGIS Pro 2.9.4, Portal version is 10.7.1) so that for all attributes with domains, the coded values display across the board in tables and pop-ups instead of the domain descriptions. We are using the map service in a third party map application in addition to our ArcGIS Portal apps, so we're looking for something that can be controlled at that service level so the change applies there as well. It appears that unchecking the option in the attribute table in ArcGIS Pro to change how domain values are displayed doesn't translate to the service level post-publishing.
Thanks in advance!
