Is it possible to customize the login page in portal for arcgis.
28652
39
08-22-2017 11:01 AM
akshayloya
I've portal for Arcgis 10.5 (behind the firewall). I have to customize the login page with the client's company logo, banner and all those. How can I do this. Any work around ?
AshrafDar
Hi Derek,
If we somehow try to customize the login page such as hiding esri logo etc, does this have any impact on the license?
Regards,
Mohammad Ashraf
DerekLaw
Esri Esteemed Contributor
Hi Mohammad,
I'm not sure what you're asking. As I've posted earlier in this thread, customizing the login page is not supported. And this should not impact software licensing.
Hope this helps,
akshayloya
Is there any way to pass username and password from my login page and writing the code for portal login in my application itself ?
Need this urgently. Kindly help.
DerekLaw
Hi Akshay,
Are you asking if you can write a custom app to login to Portal for ArcGIS? For example, a web app connecting and signing into Portal? Please see this help topic for the ArcGIS API for JavaScript,
IdentityManager | API Reference | ArcGIS API for JavaScript 4.4
Hope this helps,
akshayloya
Yes. I have used this later. Thanks
AnthonyFord
Is there any way to remove everything in the black boxes, and keep the middle login box? Ideally, I'd like to wrap the corporate colors and brand around that login box.
DerekLaw
Hi Anthony,
You can remove the "Create An Account" button from the display, please see this help topic:
Disabling users' ability to create built-in portal accounts—Portal for ArcGIS (10.5.x) | ArcGIS Ente...
Hope this helps,
RebeccaStrauch__GISP
just fyi, here is an additional note in another thread https://community.esri.com/thread/199954-require-administrative-approval-for-new-accounts-in-portal#...     re the correct formatting when adiding the disable
{"WebContextURL": [webcontextURL], "disableSignup": "true"}
see the notes in the other thread for more info.
AnthonyFord
Thank you. Now, just to disable that top bar.
EricPeña
You can also simply edit the signin.html file found in the Portal installation directory:
[Portal Installation Folder]\ArcGIS\Portal\webapps\arcgis#home\signin.html
I added a <div> with a logo and some text right before <div id="signInStyle"></div> in the signin.html file.  You could change the banner style within the signin.html file as well.
I also edited the classificationBanner property in Portal's config.js file (see Set advanced portal options—Portal for ArcGIS (10.6) | ArcGIS Enterprise)
