Icons from Symbols Points do not appear in the Legend
720
03-05-2012 10:09 AM
evandroRodrigues
Dear sirs,
I have had problems when exporting map to plot, because when I export some symbols of points do not appear in the legend.
For example use the symbol (sphere, Capital 2) to represent rural communities, however the time to export it does not appear in the map legend exported. This also occurs for other symbols.
How to solve this?
Perhaps this can be resolved by Service Pack 4 Arcgis 10
Sincerely,
Evandro Luis
Prezados Senhores,
Tenho tido problemas na hora de exportar mapa para plotar, pois quando exporto,  alguns simbolos  de pontos não aparecem na legenda.
Por exemplo uso o simbolo (sphere, Capital 2) para representar comunidades rurais; entretanto na hora de exportar ele não aparece na legenda do mapa exportado. Isso também ocorre para outros simbolos.
Como  resolver isso?
Talvez isso possa ser resolvido   pelo  Service Pack 4 do Arcgis 10
Atenciosamente,
Evandro Luís
LucasDanzinger
Esri Frequent Contributor
Hello,
If you are using 3D marker symbols, you may be running into a bug. KB Article 33063 speaks to this known issue and suggests two possible workarounds. If this is the issue you are experiencing, it is resolved in 10.1.
Luke
