Hyperlink in Portal for ArcGIS
1116
05-03-2022 04:15 AM
Anzhi
Hello I have table with huperlink field in ArcGISPRO, I need that this hyperlink will work in Portal for ArcGIS also.
Is it possible?
regards,
Anzhelika
jcarlson
MVP Esteemed Contributor
Can you give an example of the contents of this field? Portal can handle hyperlinks just fine, but they typically need to be http:// or https://, otherwise Portal re-writes the URL. Have you attempted to add these URLs to Portal and seen different results?
- Josh Carlson
Kendall County GIS
Anzhi
Hello,
My link is to file Server. that why I didn't use https
regards,
Anzhi
jcarlson
UNC filepaths will not work through a web map.
- Josh Carlson
Kendall County GIS
