How to spatial join on the fly?
671
5
04-17-2025 06:10 AM
Labels (2)
MatthewTsui5
Has anybody figured how to spatially join on the fly?
I'm struggling to build an ArcGIS Dashboard where users can see three layers (territories, districts, regions).
The data must be live since it changes daily, so it's sourced enterprise geodatabase polygon feature class (Entgdb.DBO.Territories). A district is neighboring territories, while a region is neighboring districts. [See screenshot].
I tried using symbology (fill, but no outline), but accessibilty suffers with so many 80 + districts.
RickeyFight
MVP Regular Contributor
MatthewTsui5
Hi RickeyFight,
I have tried it. Unfortunately, the doc helps to spatially join attribute on the fly between two layers. It doesn't help to visualize seperate polygons with the same attribute as one polygon.
DavidPike
MVP Notable Contributor
You can create a view in the database with geometry joins (or query layer in desktop) and publish that.
MatthewTsui5
Hi David,
That sounds promising.
By geometry join, are you referring to SQL functions like ST_UNION?
https://developers.arcgis.com/geoanalytics/sql-functions/st_union/#:~:text=ST_Union%20takes%20two%20....
DavidPike
I think you'd use option such as .STIntersects(), .STContains(), .STWithin()
Whichever operations are available within your database engine (may not be ST geom type etc.)  We're talking outside of Esri here so go to your DB documentation.  A query layer in ArcPro might achieve the same thing also (with extra steps).
