how to overlay 2 different countries to show size and area difference
2684
10-26-2011 10:42 AM
PamelaPhillips
Hello-  How can I display a map of Panama over a map of Iran to show the difference in size?  This should be easy but I don't get it.
Thanks to any and all that have the answer.
Pamela
CameronBouchard
An easy way would be to use two dataframes and overlay them in a Layout. If you print (to pdf or paper), then nobody will know how it was done.
  • In one dataframe, show Iran and any other neighbouring countries and water that you want.
  • In the second dataframe, add Panama only
  • *but ensure that the map scale is the same as the Iran dataframe.
  • *Also ensure that you don't have any other layers that might fill the Panama dataframe space (like oceans)
  • *don't give the dataframe a fill or an outline, as it needs to be transparent except for Panama.
  • Then slide the Panama dataframe onto the Iran data frame.
PamelaPhillips
Perfect and so easy.  Thanks Cameron.  I appreciate it!
