How to get all named users in Portal and ArcGIS Online
3772
11-13-2016 05:34 PM
CyrilCherian
I am trying to find out how I can get list of all named users in Portal or ArcGIS Online account using REST request.
Appreciate all help.
Cyril
JayantaPoddar
Administrators can use a command line utility, called ListUsers, to generate a list of all members in the portal.
Listing members—Portal for ArcGIS (10.4.1) | ArcGIS for Server
Think Location
CyrilCherian
Hi  Jayanta,
That is correct. I have seen that approach. But that can only be used from where the portal is installed. Isn't? I am looking for REST way of doing it. Here is the closest I can find
http://www.arcgis.com/sharing/rest/portals/fa019fbbfbb845d08cc9f0acde6dd8af/users
Here is ESRI's description of the above URL
Lists all the members of the organization. The start and num paging parameters are supported.
This I believe is for ArcGIS Online. I have tried with our AGOL account using admin token and could not successfully retrieve users. I am also looking for somthing similar for portal.
Cyril
NeilAyres
Have you tried the tools in portalpy?
PortalPy
JayantaPoddar
Try Admin Tools for ArcGIS Online for achieving the requirement.
Think Location
CyrilCherian
I had looked into PortalPy and now looking into AdminTools for ArcGIS Online.
What we are trying to do here is a small piece of requirement in a large desktop .NET application.  We may not be able to install other applications on individual client machines to support this requirement. Still I am looking through these options.
Cyril
