How to change symbology for imagery layer in Portal for ArcGIS
1318
01-28-2021 09:04 AM
DavidBondy1
Hi all,
Does anyone know if there is a way to change the symbology of an image service when publishing it to Portal for ArcGIS 10.8.1? From what I can see, it published with the default symbology and there is no way to change that before or after publishing.
JonEmch
Hey there David,
To clarify, are you speaking about using the default image template?
If so, you should be able to change it somewhat in the Map viewer: https://enterprise.arcgis.com/en/portal/latest/use/display-imagery.htm
Please let me know if this helps!
Keep on keeping on!
JonEmch
Hey there David,
Keep on keeping on!
DavidBondy1
That 100% answers my question. No idea how I missed that. Thank you!
JonEmch
Anytime, happy mapping!
Keep on keeping on!
