How can I pass content from Portal to arcGIS online?
1324
11-03-2023 08:46 AM
MDB_GIS
Our organization has been in arcgis online for 5 years. We have around 40 users of varying permissions. We recently started utilizing portal for arcgis. The main reason we wanted to implement this is so that we could directly edit our enterprise geodatabase data using field maps. One thing I haven't been able to figure out a good workflow for, however, is letting users who are a part of our arcgis online organization access that data in portal. In particular, I have a few water resources layers that I've published to portal that I'd like for our field crews to be able to access in arcgis online/field maps. Is there a convenient way to do this or is the intention to force all those users to have an additional portal account as well?
I'm trying to keep things as simple as possible. Any advice would be appreciated!
MarceloMarques
https://community.esri.com/t5/arcgis-online-questions/how-to-update-sync-data-on-arcgis-online/td-p/...
https://enterprise.arcgis.com/en/portal/latest/administer/windows/share-feature-layers-from-an-enter...
https://enterprise.arcgis.com/en/portal/latest/administer/windows/schedule-the-synchronization-of-fe...
https://enterprise.arcgis.com/en/portal/latest/administer/windows/configure-sync-settings.htm
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 32 years, my passion for GIS has only grown stronger." | “ I do not fear computers. I fear the lack of them." Isaac Isimov |
MarceloMarques
You can also write a custom arcpy script or use ArcGIS Model Builder or ArcGIS Data Interoperability Extension or Safe Software FME Workbench or FME Sever to synchronize your data.
https://www.google.com/search?q=arcpy+update+hosted+feature+layer
https://developers.arcgis.com/python/samples/updating-features-in-a-feature-layer/
https://community.esri.com/t5/arcgis-api-for-python-questions/updating-feature-layer-using-arcgis-ap...
MDB_GIS
Thank you for this response! I'm going to review these next week and follow up!
ArchitSrivastava
Hello @MDB_GIS
Including the suggestions from @MarceloMarques. It might be worth looking at "Distributed Collaboration".
Assuming the following:
  • You would want the data to remain on Enterprise Geodatabases.
  • As it's a workflow where ArcGIS Online/field maps is used, it would be continuous workflow like it would happen often maybe daily or weekly
About distributed collaboration : https://enterprise.arcgis.com/en/portal/latest/administer/windows/understand-collaborations.htm
Additionally, it also a feasible option to just add the ArcGIS Server service URL as an item in ArcGIS Online and consume that in Field Maps (make sure all the properties are enabled which are required for Field Maps)
Add a service or document from a URL : https://doc.arcgis.com/en/arcgis-online/manage-data/add-item-from-url.htm
Hope it helps!
-Archit
