Hello forum friends,
Through a georeferenced aerial photography and I vectorized ortofotoimagen apples, roads and rivers near a population center.
I need to digitize and vectorize inside apples plots and within the area of ??????construction or infrastructure based on measurements made by technicians with tape measure.
My questions are:
1 - how to divide apples based on a survey of infrastructure?
2 - you must use EDITOR OR PARCEL Cadastral Fabric? or what extension should I use?
Note: I am using ArcGIS 9.3 and the houses were built with a tape measure and the sum of all fronts and funds (length x width) should result in equal perimental size of each of the apples. That's like a kind of cadastre.
Thanks for the help I can provide.
