Help ArcGIS Portal is not lunching
1727
07-07-2017 08:09 AM
Okeke_Onyedikachi1
Greetings,
Please help I have been struggling with this for days, after successfully installing and authorizing ArcGIS Portal.I choose the selected Create  New Portal option filled the needed information then clicked Create...
A page popped out informing me that the portal has been created and would need some minutes to restart...
I have been waiting for days now for the portal to load,  but the portal has not restarted or load.
Please I need help on this.
JayantaPoddar
Close and reopen the browser. Try installing/configuring the web adaptor with Portal using the credentials of Initial Administrator. If it gets configured correctly, you can open the homepage of Portal for ArcGIS.
Think Location
JayantaPoddar
You should post your query as a question, not discussion, as questions will attract more attention than discussions.
Think Location
PaulDavidson1
Have you rebooted the server?
Give us more info please on your setup. Version, OS, hardware, what's installed on the box (portal, AGS, etc...)
-Paul Davidson
Okeke_Onyedikachi1
Am running it on  Windows Server 2012 r2, Hard drive 2tb. Ram 32G, using Google Chrome, https
PaulDavidson1
What version of Portal?  Do you have a Web Adaptor?  Hard to help without understanding of the environment.
And try using IE rather than Chrome.  If you want to use Chrome and you're on <10.5, then you need to find the patch.
Even then, I've seen issues with Chrome, especially with HTTPS/SSL
If you're using a self-assigned certificate, I suggest you don't.  They're known to create issues.
Personally, I'd recommend using the Chef cookbooks for the installation.  It helps get a consistent and known installation and will make future upgrades a lot easier.
Good luck.
