HA portal attempting to write to standby after failover
3836
12
09-19-2023 08:14 AM
TonyContreras_Frisco_TX
I have a new Enterprise 11.1 setup with HA portal. Portal1 was running as the primary, and Portal2 was the standby. I installed a patch for Portal on each server, one after the other. After both installs completed, Portal1 was again showing as primary, however I was not able to edit or create new content consistently. I have may entries of "Failed to add or update item '<itemID>'. DBUtil.doUpdateTransaction(): failed," in the Portal Admin logs, citing Portal2 as the source machine.
After searching for this error, it looked like Portal was attempting to write to the read-only database of the standby Portal machine. Once I stopped the Portal windows service on the standby, things began working as normal. I started the service up on the standby again, and the same errors are showing up. I do not see the recovery.conf or promote.dat files on either server's db directory. The portal admin shows Portal1 as the primary.
Does anyone have suggestions to prevent Portal from attempting to write to the standby Portal machine?
@JonathanQuinn
Does anyone have suggestions on how
Hi Tim, you can follow this link and start with Step 3 on the secondary Portal Server to re-register the other Portal machine.
TimHaverlandNOAA
Interesting, I'm pretty sure I tried that but didn't get a prompt to join. Will give it another try.
TimHaverlandNOAA
Hi I tried unregistering and re-registering again on a freshly-built HA portal. I followed the steps in the link you provided. This time it worked, so at least I know what the expected behavior is. Thanks!
