Get active Portal in ArcGIS Arcade when executing in Dashboard
1429
02-23-2023 10:53 AM
PhilipPenn1
Currently in a data expression in an Enterprise Portal 11.0 dashboard if I want to get a Portal I have to hardcode the Portal URL
var portal = Portal("https://myportal/portal");
This causes headaches when migrating the script from one environment to another. Given that this is executing...from within Portal itself, can I not just get the currently active/signed-in Portal i.e.
var portal = Portal();
thanks in advance,
Phil
Tags (1)
jcarlson
MVP Esteemed Contributor
I think you should post this as an Idea rather than a question.
The GetUser function behaves in the way that you're describing, where it defaults to the currently active Portal when none is specified. It would certainly be a useful feature, and I'd give it an upvote!
- Josh Carlson
Kendall County GIS
ViktoriaMagnis
Hi
I was just wondering if there was a solution to this issue?
Thanks
Vicki
