Gauss Krueger coordinate system zone 7 - north of Serbia
6481
12-16-2012 11:42 PM
KalleArsch
I go some data in dwg format and the information that this is Gauss Krueger coordinate system zone 7. The files are located in the north of Serbia directly to the Hungarian border. Since days I am searching for this Gauss Krueger zone 7 projection file and can not find it. Can someone help me?
Thank you
Misa
KalleArsch
MelitaKennedy
Esri Notable Contributor
Hello Misa,
There are a few GK zone 7 files.
Projected coordinate systems, Gauss-Kruger
Europe
   Pulkovo 1942 Adj 1958 3-Degree GK Zone 7
   Pulkovo 1942 Adj 1983 3-Degree GK Zone 7
Pulkovo 1942
   Pulkovo 1942 3 Degree GK Zone 7
The third one is the least likely one, but I don't know which of the other two is more likely.
Melita
KalleArsch
Finally I found one local who could solve me that problem:
it is MGI / Balkans zone 7
http://spatialreference.org/ref/epsg/31277/
explanation:
http://spatial-analyst.net/wiki/index.php?title=MGI_/_Balkans_coordinate_systems
benujahb_r
hi
i am new to work with arcgis. i want to project a raster data to a coordinate system. can anyone tell to find which projected coordinate system suits for a particular area. my study area covers 77-78E and 8-9N
MelitaKennedy
hi
Hello,
It looks like you're working in the same area as India Zone IV (4) or UTM zone 43N. The first uses Lambert conformal conic, and the 2nd uses transverse Mercator. Both area conformal so they maintain shapes and angles, not areas so depending on what you want to do, they may or may not be appropriate. You can find the list of supported coordinate systems in the ArcGIS installation folder, Documentation, projected_coordinate_system.pdf.
Another place which is easier to search, is http://www.epsg-registry.org and then check to see whether we support it or not.
Disclaimer: I am a member of the subcommittee that maintains the EPSG registry.
Melita
benujahb_r
thanks for replying. I am trying to prepare slope map from SRTM DEM. when i project to UTM zone 43N projection, the values i got ranges 0 to 12% which is too small. I want to know which property must be retained to get slope values.
