Feature Class Representaiton Properties Greyed Out
4088
04-16-2014 05:44 AM
EdwardGlover
I am unable to add a new marker layer to a representation because all of the buttons contained in the feature class (fc) representation properties dialog are greyed out.  The feature class is versioned and I am attempting to make this change through catalog, hence the fc is not being edited.
AlexanderKeyel
Did you check for any active locks on the file? I had a similar problem for both ArcMap (Properties: Symbology) and in ArcCatalog for a layer that I had recently created. I had edited it using Python using an Update Cursor, and even though that should not have left a schema lock, once I closed the Python window, I was able to edit the Representations again. So I'd recommend checking for other places (ArcMap, Python) using the data set, or other users using the data set, and make sure that you are the only person actively working on the layer and ArcCatalog is the only location accessing it. This sometimes requires closing ArcMap documents that once had the layer open - sometimes it doesn't want to give up those schema locks!
Also "hence the fc is not being edited" is not true to my limited knowledge of representations. My understanding is that Representations are stored WITHIN the feature class attribute table, so edits to the representations are edits to the Feature Class.
I realize this is probably too late to be of use to you, but this was the top search result when I had a similar problem, so I figured I'd post what worked for me.
