Fail to synchronize replica during collaboration
201
08-13-2024 07:22 PM
MatthiasBoucher
Hello,
I have one ArcGIS enterprise portal synchronizing items every night to ArcGIS Online through a one way Collaboration. Most of my Feature Services are synchronizing successfully but one item is failing every time. The following messages appear in the portal logs during the synchronization attempt :
In the portal sharing logs I have the following messages :
I've been able to create a local replica containing the same data using arcpy, so I don't think there is some corrupted data preventing the replica to work. The size of the replica is also quite small, so I don't think disk size is an issue. I can't find a clue about the severe message "Direction is 'download'", hence this ticket.
Thank you for your help.
Versions : ArcGIS enterprise 10.91. The Feature Service I am trying to synchronize is not hosted. It refers to a PostgreSQL geodatabase. Data are not versionned, but has archiving enabled, contains globalids, and I ran the arcpy "Enable replica tracking" tool on them.
TimoT
It would be a good idea to closely double check that you have met all requirements as per Esri documentation:
One thing you may have missed is that there are certain fields you must not hide.
Timo
MatthiasBoucher
Hello Timo
Thank you for your answer. Judging by the link you provided me, I am in the 1st scenario (archived but non versionned data, one-way synchronization). I tried to re-publish the FeatureServer because I wasn't aware of this publication option :
but unfortunately this had no effect, I still have the same error message in the portal logs :
The FeatureServer uses data from a geodatabase, so I don't know why the log message refers to a 'hosted feature layer'.
I also checked the fields of the 5 feature layers I'm trying to publish, none of them have hidden fields (only one has a highlighted field).
I copy/paste the data from the original database to a recent PostgreSQL database, then published it and synchronized it through collaboration : it worked. So maybe the problem indeed comes from the original datasource itself ?
