Fail ExportSite on ArgisServer
880
12-14-2018 09:44 AM
GustavoDrets
New Contributor II
While trying to run ExportSite on ArgisServer fails with "Export operation failed. null" message. ArcgisServer is linked with a pair of  HA DataStores. Any help would be appreciated
Tags (1)
JonathanQuinn
Esri Notable Contributor
What version are you using? There's a bug fixed at 10.6 where corrupt/missing thumbnails would cause exportSite to return a similar, but not identical error. Can you run the export with DEBUG logs and see if any more information is logged?
GustavoDrets
New Contributor II
Thanks for  your response , I am using 10.6.1.
I am using Portal Administrator Directory, and do not know how to enable DEBUG log for exporting
Thanks
Gustavo
JonathanQuinn
Are you running a backup of Server, or of Portal? You can't run a backup of Server through the Portal Administrator Directory.
GustavoDrets
New Contributor II
Sorry about muy misleading previous mail
I ment arcgis server adminsitration
Regards
Gustavo
NicolasGIS
Occasional Contributor III
I just ran into the same error this morning while making a backup with webgisdr tool.
The ArcGIS Server failing was the hosting one.
Took me a while to find out the root cause because the error logged was not very talkative but I finally found it: after a reboot of the VM, the drive hosting the "arcgiscache" folder was not mounted thus inaccessible. After mounting it back, the issue was solved.
