ESRI Maps Popup Dialog
2994
09-30-2014 06:54 AM
ChrisMartin7
When I launch Excel 2010 and click on the ESRI Maps tab I receive the following message:
"Functionality such as the following will not be available due to the configuration of your Portal for ArcGIS.
  • Share Map
  • Share Layer
  • Add Excel Data using the Address Location Type
  • Select Features by drawing a rectangle
  • Find Near Selection
Any takers?  Thanks!
JakeSkinner
Esri Esteemed Contributor
Hi Chris,
I believe you are receiving this error because your Portal is not federated with ArcGIS Server.  See the following link:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
ChrisMartin7
Thanks for the reply Jake.  Portal is federated.
