Error: Unable to save your settings at this time
2948
10
09-04-2018 02:50 PM
PawelGanczarski
I'm not able to save changes in "edit settings" tab in Portal for ArcGIS 10.6 (windows). I've applied the solution provided:https://support.esri.com/en/technical-article/000012316  without success. The text is the "organisation description" is short and simple. I've used the HTML editor to find problems with the text, but it appears similar to any text entered.
I'm baffled how else that can be approached.
Any help will be greatly appreciated,
Best regards,
Pawel
JeffreySutherland
Hi Pawel,
Sorry for the delay in response.
To further assist in debugging this issue, it might be best to contact ESRI Technical Support. They should be able to provide additional troubleshooting suggestions.
Jeff
