Error Assigning a GeoAnalytics Server in Portal 10.5.1
2309
12
08-15-2017 05:17 PM
rbae
I am unable to add a GeoAnalytics server in ArcGIS Portal 10.5.1 (see attached screenshot).  This worked in 10.5...
The server federates without any issues, and it is licensed as a GeoAnalytics Server.  Does anyone have any suggestions?
-Ryan
Sergio_EduardoGalindo
If I understand well, I should unfederate, switch to "http and https", then federate again using "http" urls, and switch back to "https only" ?
thanks in advance
JonathanQuinn
Esri Notable Contributor
There's no need to unfederate, just set the protocol of the federated Server to http and https and then try to update the federated Server's role.
Just did it, still the same error.
This is very frustrating.
Thanks!
