Hi
We have a couple of complex webmaps in Portal with lots of customised popups. We need to get the webmap to look at services from a different server (they will be identical in other than the location). We have tried to use AGOL Assistant, but cannot get it to log on to Portal. Is there another way to do this? I wondered if there was some way I could access a file (json?) to manually update the location of the services?
Many thanks
Hi Mark Cooper,
I regularly use the ArcGIS Online Assistant to log in to Portal. How come this route doesn't work for you?
Egge-Jan
Hi
Im trying to use direct login. Which do you use? We use the Portal built in security rather than AD if that makes any differece
