Domains and Portal for ArcGIS
1471
10-09-2020 01:18 PM
RyanEckdale-Dudley1
I have added a coded value domain using short integers to help users enter years quickly.  However, after publishing the service to portal and adding it to a web map I found that the drop-down list for the domains is now gone.  Has anyone else experienced this?
RandyBonds_Jr_
I'm having the exact same problem. Things I've tried with no success:
  • Deleting the service and re-publishing
  • Deleting the domain and recreating
  • Changing the "Max Number of Coded Domains" value on the service to a higher number
  • Adding another field and domain and publishing
Would love to hear if someone figures this out.
RandyBonds_Jr_
So, I was able to make it work. I changed the service from a "Shared Instance" to a "Dedicated Instance" and the domains showed up. Hoping this helps someone out there!
