Copy webmap and service from one portal to another
5158
09-29-2016 01:01 PM
ChrisPedrezuela
Hi guys,
We have UAT Portal and Production Portal (version 10.3), I was just wondering if anyone has already attempted to copy items from one portal to another, either thru automation or whatever. This idea is because sometime after publishing a service in our UAT portal, I create a webmap, classify the map services ins such a way and create custom popup layouts. Now if I want to migrate this to our Production portal after my client approved the UAT content, I don't want to go thru the process of setting up the webmap and pop-ups from scratch. Anyone can give advice?
Cheers
ChrisPedrezuela
PaulDavidson1
You can also use the AGOL Assistant (there's an online version or grab the code from GitHub and customize it locally)  AGOL Assistant
That's a point and click access vs. scripting.
And GeoJobe offers a commercial product similar  to the above but I think with increased functionality.
ChrisPedrezuela
This is good as well Paul. But this is just AGOL to Portal, I need Portal to Portal.
ChrisPedrezuela
I take it back, it does work for portal to portal
