Does anyone know wich is the best geographic transformation to convert a raster from GCS_WGS_84to to ED_1950_UTM_Zone_32N?
Thank you very much,
Alessandro
What is the data's extent? Or, what area are you interested in? If you have ArcGIS Desktop, look in the documentation folder and open the geographic_transformations.pdf file. Or it's here online:
http://resources.arcgis.com/content/kbase?fa=articleShow&d=21327
Don't worry about the direction of a transformation. Generally, transformation convert from a older or local geographic coordinate system to a newer or more general coordinate system. Currently, all transformation can be applied in either direction and the software will handle it for you.
Melita
