Changing an item id of an existing web map on Portal for ArcGIS
3451
12-03-2021 02:59 PM
pzhuchkov
I want to know if it is possible to change an item id of an existing web map on Portal for ArcGIS.
Context
A lot of external services are related to item ids of existing web maps. It is necessary to set up a new Portal for ArcGIS on another server. Then all web maps will be republished on it. I would like to change all ids of republished web maps for old ones to save my links with external services.
ReeseFacendini
Esri Alum
There is not a way within Portal for ArcGIS to alter an ItemID.  Once the ID is assigned that's what it will be until you delete and recreate the item.
If you will have the old and new Portals up and running at the same time, you can use clone_items within the ArcGIS Python API and that function will allow the web map to keep its ItemID.  Here is the link to more detail about clone items
ReeseFacendini
Esri Alum
MapNat
Adding on to @ReeseFacendini 's comment.
To allow a cloned item to keep its item ID, I needed to set preserve_item_id to true:
cloned_flyr = target.content.clone_items(items=[hosted_flyr],
                                         preserve_item_id=True,
                                         owner="owneraccount")
This isn't covered in the Cloning Content article which only goes over the setting of the typeKeyword and how that is used to identify the source item ID associated with a cloned (target) item. By default, the cloned item has its own item ID which is not the same as the source item ID, but it keeps track of the source item ID in a typeKeyword.
I have been able to clone a feature layer, webmap, and Experience Builder app... not without various problems. But with the desired copied item IDs.
