Cannot open map in Map Viewer but works in Map Viewer Classic
6744
6
01-29-2024 02:38 PM
TimSexton1
I just upgraded my portal from 11.0 to 11.2.  Everything seems to be working for the most part but when I attempt to open an existing map in my portal's content, it will only open in the Map Viewer Classic and will not open in the "Map Viewer".  I also noticed that I can no longer "Add New" in the portals content section, just a blank window opens.  I'm wondering if these are related?
New item screen is blankNew item screen is blank
TimSexton1
I had to set a web context URL in portaladmin that pointed to my custom dns entry for portal. This fixed the Map Viewer issue.  I learned this at DevSummit.
https://enterprise.arcgis.com/en/portal/latest/administer/windows/using-a-reverse-proxy-server-with-...
TimSexton1
Disregard this issue. I'm leaving it here in case others experience a similar situation.  Evidently after upgrading everything you need to clear your browsers cache.  This fooled me because it was working after upgrading the server and portal, then I upgraded my web adaptor (named it the same) and after that is when the trouble started.  Web apps 101 - clear the cache!
ODWC_GIS
@TimSexton1  I've cleared my cache twice now, and I still encounter the "There was an error" whenever I try to open Map Viewer in my Portal 11.1 site.  Map Viewer Classic still works.  Any suggestions for when clearing the cache doesn't resolve the issue?
TimSexton1
In 11.2 I'm actually still seeing some issues with the "Map Viewer" where the "Map Viewer Classic" works and the new one does not.  Have you tried an incognito window to 100% eliminate caches all together? Some times clearing the cache in the standard browser alone doesn't seem to clear it all the time.
TimSexton1
EdwardBuckley
We experienced the same thing going from 11.1 to 11.3 and this fixed it for us too!
slaurila
Thank you! this worked for me upgrading 10.9 to 11.1
