Can you create uppercase or dynamic text?
7234
6
02-09-2011 01:36 PM
TomMagdaleno
I want to display "MONTH YEAR" so I used this dynamic text <dyn type="date" format="MMMM"/> <dyn type="date" format="yyy"/>, but the Month has first letter capitalized, the rest lowercase.  How do I change them to all uppercase?
JustinOdell
The easiest way to do this is by using the <ACP> </ACP> (All Capitals) tag.
e.g. <ACP><dyn type="date" format="MMMM"/> <dyn type="date" format="yyy"/></ACP>
NelsonDe_Miranda
If you're using VBScript - UCASE(String)
If you're using Python - str.UPPER(String)
Replace string with the code of the dynamic retrieval of the month.
TomMagdaleno
Thanks for the reply.  More specificially how do I format it to still work with dynamic text?
I tried:
str.UPPER(<dyn type= "date" format="MMMM"/> <dyn type="date" format="yyy"/>)
I get:
str.UPPER(February2011)
NelsonDe_Miranda
What you could do, although I haven't tested it is dump the dynamic text for month into a variable and then modify the variable at output.
ie. month = <dyn type= "date" format="MMMM"/>
str.UPPER(month)
TomMagdaleno
Thanks Cartographer, that did it!
JustinOdell
DAVIDWADSWORTH_LVVWD
Many thanks. Exactly what I was looking for. Thanks for sharing.
