Can't find GPS help anywhere!
557
10-28-2011 05:19 AM
KevinDoyle
I'm using GPS pathfinder office to process waypoints and I keep getting this:
"No processing performed as base data does not have carrier data"
I'm pretty sure it has something to do with me configuring the IP address of the server of the basestation I use but I don't know how to do that.
Can you modify the IP address of a "system-defined" server?  Is it done through the Correction Wizrd?
Help!
KevinDoyle
I figured out what was wrong. I was connecting to the server but IP address was off. Thanks anyways!
